Datum Efratom LPRO Rubidium Lamp removal
Discussion in 'Electronic Equipment' started by Antonio Iovane, Jan 2, 2008.
  1. Hi all,
    does anybody out there have any experience in replacing the lamp on an
    LPRO rubidium oscillator?
    I have two of these, one working and another which reads "lamp volt" =
    zero. I feel it is not a matter of lamp, as the lamp housing doesn't
    heat (it should). I would try swapping the lamps between the two units
    for diagnosis, at least to know if I could rely on a spare lamp from
    the faulty unit, but before attempting to loose the bolt which holds
    the lamp into its housing I would like to know if this could damage
    it.
    By the way, does anybody have the schematics of LPRO?
    Antonio I8IOV
