Datasheet for diodes
Discussion in 'Electronic Components' started by John B, Nov 29, 2003.
  1. John B
    John B Guest
    Tring to find datasheet or equivalents for the following 2 diodes. They
    appear to be zenors.
    BZV47C24 (ST microelectronics)
    CI5PH
    I've tried every search engine and database imaginable but nothing turns up.
    I can't find any listing on ST's site either.
    thanx,
    John
  2. Chaos Master
    Chaos Master Guest
    John B() slammed into the keyboard with
    a 100-lbs hammer:
    Not zenors. Zeners.
    24 volts zener, AFAIK. Sorry but I can't help you more because I've never heard
    of this diode.
  3. Franc Zabkar
    Franc Zabkar Guest
    Google says this is a 2W 24V zener.
    C15 = 15V ?, PH = Philips?
    - Franc Zabkar
  4. Guest
    http://www.elab.ntua.gr/hlektron1/BZ47.pdf
    As for the CI5PH - there's a typo. It is C1PH
    (C one 5PH). Go to:
    http://www.anatekcorp.com/faq/applianc.htm
    then search in page for C15PH
  5. I copied and pasted the above into the browser, and it came back with
    not found error.
    @@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@,@@[email protected]@[email protected],@@[email protected]@[email protected]@[email protected]@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@
  6. Guest
    Try it again. It works for me both ways - clicking on it
    here, or copy/paste.
  7. Franc Zabkar
    Franc Zabkar Guest
    It doesn't work for me.
    - Franc Zabkar
  8. John B
    John B Guest
    many thanx.
    John
  9. Guest
    I hate it when that happens. :-(
    It works perfectly for me on both Netscape 4.75 and Netscape 6
    on this machine, and on Internet Explorer 6.0 on another machine.
    I just tried it again on all three. You do need a plug-in for
    ..pdf files - could that be the problem? Also, pay attention
    to the capital letters if you type it in. If you use bz47 instead
    of BZ47, it won't work.
    You could try to Google bzv47c. I just did that, and the
    3rd item on the first search results page is titles
    2W ZENER DIODES and points to the url I posted.
    Worst case - if you can't get it to work, I can try to
    download it and E-mail the file to you.
  10. Franc Zabkar
    Franc Zabkar Guest
    I'm using Opera 7.11 and I'm clicking on the URL, so there is no
    possibility of a transcription error. In any case, I've just tried the
    link again and it works this time. Must have been a problem at the
    other end.
    - Franc Zabkar
  11. Guest
    Great! I also sent it to you via Email - glad to
    find that wasn't necessary.
