Datasheet 29lv800bbtc-70, ar2313A
Discussion in 'Electronic Design' started by [email protected], Jan 15, 2007.
  1. Guest
    I have tried justfuckingoogleit and came up empty.
    Inside my DLink DI-524 Rev C1 "wireless router" are a few chips. I
    wish I knew what they were.
    1. 88E6060 a 6 way switch. Got the datasheet.
    2. m12l64164A A 1M x 16 bank switched DRAM. Got the datasheet.
    3. AR2313A a CPU and Radio. May be a MIPS core. May be ARM core.
    4. 29lv800bbtc-70 Seems that an eeprom should be on the board. This
    is what's left.
    Anyone know where datasheets are available? Is Atheros cooperative
    with small outfits?
  2. John  Larkin
    John Larkin Guest
    That last one sounds a lot like the part number for an 8 mbit flash
    memory. ST maybe?
    Jokn
  3. PeteS
    PeteS Guest
    The 29LV series was, IIRC, a boot block flash originally from AMD which
    was moved to Spansion
    http://www.spansion.com/
    Spansion is a joint venture of AMD and Fujitsu according to the site.
    You can find the AM29LV800 here:
    http://www.spansion.com/products/Am29LV800D.html
    Your part is a 70nsec device.
    Cheers
    PeteS
