Data throughput of embedded ethernet
Discussion in 'Electronic Design' started by Richard Hosking, Aug 13, 2005.
  1. Dear all
    There are a lot of embedded ethernet cards out there now. I was
    considering the use of one of these to stream data from a fast serial
    ADC to PC for analysis - digital radio app.
    What sort of data rate could be achieved for 2 16-24 bit I/Q words and
    what card would you use?
    The max baseband bandwidth of the ADC is up to about 300KHz (ie 2 X
    600KSamples/sec
    What would be the limiting factor in this scenario?
    Richard
  2. Guy Macon
    Guy Macon Guest
    2 channels at 300,000 24-bit samples per second is 1.2 megabytes
    per second. 16-bits is 1.8 megabytes per second. A good rule of
    thumb for real-world network performance is:
    10baseT = 1 megabyte per second
    100baseT = 10 megabytes per second
    1000baseT = 30 megabytes per second
    So it looks like a bog-standard 100baseT Ethernet link will handle
    your data stream. and it dooesn't much matter what card you use.
    Just make sure it is set up for full duplex and that nothing else
    is on that network.
    You will, of course, need a processor that can handle the load,
    enough storage, etc.. but I don't see your network link as being
    a problem.
  3. Mac
    Mac Guest
    On Sat, 13 Aug 2005 15:30:48 +0000, Guy Macon wrote:
    [snip]
    As Willy Wonka once said: "strike that: reverse it." Or something like
    that. ;-)
    --Mac
  4. Richard H.
    Richard H. Guest
    300KHz * 2 ADCs * 24-bit = 14.5Mbps, including IP overhead, assuming
    large packets.
    Clearly 100Mb is needed; full-duplex always preferred. This is also
    about 10k packets/sec. I've pushed the ASIX over 20k/sec, so you're in
    the right range.
    Your limiting factor will be the protocol used for the transfer. Behind
    that, the MCU and the rate it can get packets into the buffer.
    UDP is highly recommended, especially if you can tolerate packet loss
    (which should be 0 anyway for local applications). TCP will cause you
    nothing but headaches unless you absolutely need to guarantee 100% data
    delivery. (It'll require a lot of buffer RAM for retransmissions, and a
    lot more overhead in the MCU, and it may take a chunk of tuning to get
    it up to the rates you need, even locally.) UDP can also run with
    payload checksums turned off, further reducing the MCU load.
    Then, finding a creative way to load the data directly from the ADC into
    the Ethernet NIC will be key to how many cycles will be needed on the
    MCU. (E.g., setting the NIC in bulk write mode, toggling the ADC data
    onto the bus, and toggling the NIC to latch the bits; a la DMA
    controller style.)
    If the MCU doesn't need to manipulate the data (e.g., even for
    checksums), you can avoid the overhead of copying it into the MCU and
    then right back out; this is the most frequent and biggest operation, so
    it's a big factor. Part of this will be driven by whether the ADC is
    being read serially or 8/16/24 bits wide, and the size of its buffer (if
    any). (I.e., if it can sustain pauses in the stream, and whether the
    MCU needs to handle all the data.)
    There are 3 ISA-style 100Mb chips out there; the rest are integrated or PCI.
    http://www.asix.com.tw/emb-non_ax88796.htm
    http://www.davicom.com.tw/eng/products/dm9000.htm
    http://www.smsc.com/main/catalog/lan91c111.html
    (http://www.edtp.com/ recommended for ASIX protos)
    Cheers,
    Richard
  5. Has anyone made a card where the "ADC finished" signal feeds a counter
    and a DMA circuit on memory that is shared with the CPU?
    Some Xilinx part could compute the CRC values in parallel so that no CPU
    overhead would be used for that. I suppose the same part would pre-fill
    the address, protocol, and other packet headers as well as putting the
    first user data address into the counter.
  6. TheDoc
    TheDoc Guest
    Actel has an ethernet core module.. add some extra logic to control the ADC,
    put the results directly into the ethernet controller's memory and send..
    minimal cpu overhead..
