Dart thrown at LCD pc monitor
Discussion in 'Electronic Repair' started by N_Cook, Aug 25, 2012.
  1. N_Cook
    N_Cook Guest
    I assume it punctured the active surface as a small hole shows permanently
    white . I would have expected a line and or row or a few such lines to be
    non-funtioning, at least one side of the hole, why not?
  2. c4urs11
    c4urs11 Guest
    Dart likely thrown from a drone, hence no collateral damage.
  3. If it actually punctured the LCD, there would be much more serious
    effects. I'd guess it only took out a bit of the front polarizer.
    sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
  4. N_Cook
    N_Cook Guest
    I'll have to find a piece of polarizor film and see if colours return in
    that spot Then how to cut a tiny bit of the film and plug the hole
  5. N_Cook
    N_Cook Guest
    Polarizor film at the right angle does bring back to normal, whether a
    little circle of it over the hole is more objectionable than permanent
    hite - debatable.
  6. micky
    micky Guest
    Have you done this? Seems like a very tiny "drop" of something grey
    or black would be better. Maybe that epoxee that comes out grey,
    either PC-70 or the one in tubes which is thinnebut if you get a small
    enough bit, maybe it won't run. The second is famous but I can't
    remember the name.
    II've used the windshield repair kit and the tube that the stuff is
    pumped through is at least 3mm. Won't that cover lots of lcds?
