darlington replacement ?
Discussion in 'Electronic Components' started by mark krawczuk, Sep 8, 2007.
  1. hi, i have a blown npn darlington 2sd1525 from a cars fan speed controller
    , and its rated at 30 amp , doesnt this seem excessive ? i doubt it if
    the fan would draw more than 5 amp ....
    anyways , i have had a pretty good look on the net , and the only
    direct replacements are only available over seas ,
    is there a commonly available equivalent npn darlington ? that i could use
    thanks, mark k
  2. No, it doesn't 'seem excessive'. The _instantaneous_ peak current as you
    turn on, will typically be several times the 'normal' operating current.
    Transistors, blow very quickly, and if the unit is fused at perhaps 7A,
    you would need to be using a transistor this sort of size, to have much
    hope of the fuse blowing before the transistor...
    Since the unit is a 'speed controller', it is almost certainly a PWM
    design,
    Just get a 2SD1525. Several US suppliers show them in stock, who will post
    to Australia. 'aeri' in Australia, will supply directly, if you don't want
    to fiddle around dealing with an overseas company.
    Best Wishes
  3. GregS
    GregS Guest
    My sub book says 2SD1597
  4. hi, would either of these be ok ?
    MJ11016 NPN Power Darlington Transistor
    MJ11032 NPN Power Darlington Transistor
    these are easier to get for me.
    thanks, mark k
  5. G
    G Guest
    Try it.
    greg
