Danfoss autopsy
J.E.B.
Recently I dissected a danfoss variable speed a.c. moter drive. I
found what looked like two transformers with only to wires coming from
each. Are these transformers? If so how would this work? anybody
familar with danfoss drives?
John Popelish
They sound like inductors. I'll bet that the cores consist
of a stack of Es and a stack of Is separated by a thin
spacer, rather than interleaved Es and Is the way
transformers are made.
J.E.B.
Thanks for the reply John. Pardon my ignorance, But what purpose would
these serve? P.S. This is a VLT 5000 series BTW.
John Popelish
I can only guess, but inductance limits the rate of rise of
current when a voltage is switched on. This effect can be
used as a way to figure out that the motor leads are shorted
and switch back off before the short produces damaging
current levels, or as high frequency noise filter
components. If being used in the motor circuit, I would
have expected 3 of them. With only two, they are more
likely part of the supply noise filter. Is this drive
powered by single phase or 3 phase?
J.E.B.
3 phase. 460 delta.
H
Homer J Simpson
Either they are chokes or there is also one large wire going through each.
J.E.B.
These are wound with what appears to be 16 to 14 gauge.
H
Homer J Simpson
4. Intermediate circuit coils
Smooths the intermediate circuit current and limits the load on AC line and
components (AC line transformer, wires, fuses and contactors).
jntel
They are DC line reactors. There is one placed in the (-) and one placed in
the (+) leg between the 3 phase input full wave bridge rectifier and the
capacitor bank. They are used for harmonic control. External input line
reactors are not needed.
Jeff
Similar threads
B
Replies
5
Views
1K
Matt Giwer
M
C
Replies
Views
1K
Clive Mitchell
C
C
Replies
Views
986
Clive Mitchell
C
