A
Adrian Jansen
Hi All,
I am considering using a Dallas DS18S20 temp sensor for a remote (
outside air temp ) sensor. Sensor will be at most a few feet from the
processor doing the measurement but on a 2 wire ( ground and signal )
cable plugged into the instrument. I would like some way of protecting
the processor in case someone connects the 1-wire line either to ground,
or worse, +12 volt main supply. I cant see any nice easy way of doing
this given the drive constraints of the 1-wire system ( 1K5 pullup to +5
volt supply, processor pin pulls low to communicate on bus ).
Any ideas welcome.
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
Any ideas welcome.
Regards,
