DAC
Discussion in 'Electronic Design' started by john, Aug 25, 2005.
  1. john
    john Guest
    Hello,
    Has anybody worked with the analog Digital to analog converter
    AD5532HS? If yes please let me know. I am having some problems with its
    offset_in and Ref_in pins.
    Regards
    John
  2. PeteS
    PeteS Guest
    Exactly what problems are you having? I've used one of the same family,
    and although I had no real problems, you have to be a little careful
    about source impedance on those pins.
    Cheers
    PeteS
  3. john
    john Guest
    Hello,
    The ouput of the DAC is going to the non- inverting input of an op amp.
    Now, when I apply 2.5 volts to the " Ref_in" and " "Offset" pins of the
    DAC, the DAC outputs -2.4 volts , and in return my opamp outputs the
    -15 volts. Opamp has dual power supply of + - 15volts. The inverting
    input of the opamp is grounded.
    I need to output zero from this DAC at the power up when its not
    getting any digital data. Please advice
    thanks
    Regards
    John
  4. PeteS
    PeteS Guest
    I am not sure you understand the functioning of the DAC. Vref in
    requires a stable 2.5V reference. Whether you want to apply that to the
    Offset in pin is another matter.
    The DAC outputs a nominal 5V span, and applying 2.5V to the Offset in
    pin sets the output range at -2.5 to +2.5. Note that if you are only
    going to -2.4V, your supplies to the DAC may be a little low (it can
    only get within 2V of the power supply rails)
    The output is -2.5V for a code of 0 and +2.5 for a code of 0x3FFF (14
    bit device) with Voffset = 2.5V. It would be 0V for a code of 0 with
    Voffset(in) = Ground, and 5V (assuming your power supply is >7V for the
    analogue section) for a code 0f 0x3FFF. If you just turn the device on,
    I would expect it to have 0 in the DAC register, so you could expect
    the output to be at the negative maximum.
    The output voltage of the device is given by:
    Vo = 2 x V(DAC) - V(offset_in)
    Where V(DAC) = [Vref(in) x Code] / 2^14
    If you want to output zero from the device at power up, then tie
    Voffset(in) to ground.
    Cheers
    PeteS
Similar Threads
  1. DAC
  2. DAC
  3. DAC
  4. dac
Loading...
