Cycle counting in LTSpice?
P
Paul Burridge
I've been running simulations were I'm looking for slight frequency
variations in the output for certain changes to the component values
in the circuit under test. Is there a way of getting LT to count the
number of cycles output during the course of say a 1uS portion of
transient analysis?
p.
H
Hernán Sánchez
I usually do an FFT analysis.
Right click on transient graphic and select FFT.
Hernán Sánchez
James Meyer
transient analysis?
p.
When the only tool a man has is a hammer, all his problems begin to look
like nails.
Jim
G
Genome
Paul Burridge said:
transient analysis?
p.
Well, notwithstanding the fact that I think your a basic Fucking Idiot......
I would recommend that you take your finger out of your ass and prod on the
televison thing in front of you whilst going...... 1, 2, 3.....
DNA
"Paul Burridge"
Thumb up bum, Brain in neutral.
P
Paul Burridge
Whereas *you* are a basic, drunken idiot.
Not practical for slight frequency variations at HF (clue: you'd have
to count tens of thousands of cycles to get any meaningful result.
Pretty tedious one-round, let alone for repeated passes!
DNA
"Paul Burridge"
Have another swig of gin and go back to sleep.
K
Ken Smith
transient analysis?
You can make a model of a frequency counter and add it to the system.
P
Paul Burridge
He! That's a novel solution!
Actually I've adopted Herman's suggestion after Mike Englehart posted
a demo of how it worked on the cad group.
John Larkin
transient analysis?
p.
For things like crystal oscillators, where you're interested in PPM
variations in frequency, I usually just break the loop somewhere and
do a narrow-span AC plot of loop phase versus frequency, and look for
the zero-phase crossing. That's way faster than trying to derive
oscillation frequency from a transient analysis, and the slope of the
phase crossing is useful to see, too. For a transient analysis to be
frequency-accurate, you need to use an absurdly small time step and
wait out a lot of cycles - tens of thousands, sometimes - for
steady-state.
The AC phase thing assumes linearity, so it has limitations of its
own.
John
P
Paul Burridge
steady-state.
Thanks, John.
I've noticed that the time step is critical for this type of
simulation. Small changes in fequency result in zero output for some
strange reason, until the time step is re-adjusted to compensate for
it whereupon oscillation mysteriously reappears at the new frequency.
This completely threw me for 24 hours late last week as it appeared as
if the circuit under test would produce a waveform that totally
collapsed upon the slightest change in its output frequency!
John Larkin
Thanks, John.
simulation.
Yes, the real universe probably doesn't have time steps.
And speaking of injection locking, I'd suspect that a simulated
oscillator will tend to lock to the Spice time steps.
John
John Woodgate
I read in sci.electronics.design that John Larkin <jjlarkin@highlandSNIP
techTHISnologyPLEASE.com> wrote (in <89n440pfpjj4kduc244a7nrcm7tsqu64l6@
4ax.com>) about 'Cycle counting in LTSpice?', on Sun, 29 Feb 2004:
Isn't the time quantum supposed to be the time it takes light to travel
the Planck distance? I expect Kevin knows.
G
Genome
Paul Burridge said:
Idiot......
Exactly, know thyself.
DNA
K
Kevin Aylward
travel the Planck distance? I expect Kevin knows.
Qualitatively yes. It certainly seems that time *must* be discrete.
Simple logic rules out simple continuous existence of any physical
construct. An infinite number of real physical points between 0 and 1 is
simply absurd. All measurements must always ultimately resolve to one of
a measurement of length so therefore, so must time.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
http://www.anasoft.co.uk/NewBeginning.mp3
"quotes with no meaning, are meaningless" - Kevin Aylward.
