Cyberhome CH-DVD 500 DVD Player Repair
Discussion in 'Electronic Repair' started by nospam, Feb 15, 2004.
  1. nospam
    nospam Guest
    I have a Cyberhome CH-DVD 500 DVD Player which uses a Cyberdrive CW058D
    CD-RW drive. The Player will play audio CDs, but will not play a DVD.
    It continually searches the DVD and then gives up. I know that the
    problem is with the drive, as I have a second one that I swapped the
    drive into. It seems as though the drive is out of alignment (I already
    tried cleaning the lens). There are two adjustments on the laser
    pickup. Does anybody have any information on alignment of this drive ?
    Has anybody run into this problem ? Any help would be appreciated.
  2. James Sweet
    James Sweet Guest
    IIRC these contain two separate lasers, one IR for the audio CD's and one
    red for DVD's, I may be wrong though.
  3. Indiana
    Indiana Guest
    Actually that isn't true at all. They are just DVD-ROM drives in
    there but Cyberhome used some old drive cases that were from a CD-RW
    drive. So the drive label is incorrect and isn't what the drive model
    actually is.
  4. chienli
    chienli Guest
    hi I have the exact same problem with the exact same cyberhome model!
    did anyone ever resolve this problem? also, is there a firmware
    upgrade I can do? maybe its a controller card issue?
    any help appreciated!
    thanks!
    cma
