Could you give a very roughly speaking idea of what "peanuts" really might
translate to in terms of US dollars? Are we talking tens of dollars,
hundreds of dollars, thousands, etc?
A few hundred to maybe a thousand, US$, per copy depending on size,
materials, number of different parts required, finish (often they
require sanding and painting to get them to look close to the final
parts). Complexity doesn't matter much. That's assuming something you
can easily hold for a few minutes at arm's length, if it's something
like a 19" CRT monitor housing, the methods and or/prices would be
different. Creating the solid model is not included, and that work
would depend on how much design work was involved and how complex the
part is. The 2-D drawings should be created as secondary to the 3-D
model in this day and age.
The solid model is pretty cute in itself, you can (using a free viewer
program) rotate and zoom in on features of the parts, assemble them,
check for interference, and apply materials (blue plastic matte
finish?) to them, adjust lighting and get an idea how the product will
look.
Also what do most people normally use to do the part design and the solid
modelling? I assume this is some sort of CAD type program? Are there
industry standards and formats for this type of stuff?
Autocad Inventor, Solidworks, Pro-Engineer, Catia. Some have
free/cheap versions, but the full versions of most are fairly
expensive. IGES (a vector-like format) and STL (a raster-like format)
are two standards for files. STL files generally are pretty portable,
IME. Those programs above are not ideal for actually creating swoopy
shapes using NURBS (kind of the 3-D equivalent of Bezier curves), some
people say Rhino-3D is good for that, then take it into another
program to continue work on it.
A few hundred to $1K is very cheap compared to even a prototype
injection mold, and it makes it much more likely that you'll a) get
good orders in advance of buying the mold and b) the mold will come
out right. If you're thinking of exhibiting at a trade show, taking it
to buyers who can place big orders, etc. don't even think about it.
Best regards,
Spehro Pefhany
