Curve Tracer
Discussion in 'Electronic Components' started by als, Dec 13, 2003.
  1. als
    als Guest
    Has anyone here built a reasonably good curve tracer
    preferably with capability to drive FET's at up to
    200v and 5-10A? I would not mind spending the time
    to build same, if someone has a decent design already
    drawn up. Getting tired of hassling with my kludge :)
    <als>
    alsAThalDASHpcDOTorg
  2. mike
    mike Guest
    I toyed with the idea several times. Was gonna use a PIC processor
    and do it all in software. Never figured out how to get rid of the
    thermal effects. The current state depends a lot on the temperature
    which depends on previous states. With an analog machine, the
    rep rate is deterministic and you get the same picture every sweep.
    Get the schematics for the TEK 5CT1/7CT1. You'll have to beef it up
    for 10A, but the concept is the same. 576 is even better and already
    does the high volts/amps.
    The concept is trivial. The details for all the range switching, modes
    pnp/npn/fet will drive you ntuz.
    mike
    Toshiba & Compaq LiIon Batteries, Test Equipment
    Honda CB-125S
    TEK Sampling Sweep Plugin and RM564
    Tek 2465 $800, ham radio, 30pS pulser
  3. als
    als Guest
    Share 'em?
    Roger that. Got the concept down. It is definitely the range switching,
    modes, etc, that are driving me "ntuz". :)
    <als>
    mike
  4. als
    als Guest
    Thanks. Already seen it.
    Not quite what I am looking to do.
    <als>
  5. mike
    mike Guest
    It's not like I didn't try...
    ----- The following addresses had permanent fatal errors -----
    mike
    Honda CB-125S
  6. als
    als Guest
    Spam-catcher. Sorry. Thought my email was in my .sig ---
    try: als_AT_hal_DASH_pc_DOT_org
    or: fsmyth_AT_txucom_DOT_net
