C
[email protected]
Are current transformers designed to operate on a specific frequency
??? I know filament type transformers are designed at certain
frequencies such as "normal" transformers for doorbells, ac equipment
etc... designed for 50/60 hz use and aircraft transformers designed for
400 hz... but I am having trouble with a current transformer/ switch
that seems to operate erratically at 20 hz fed from an inverter
circuit. I looked at the specs on the transformer and it is spec'd at
50/60 hz.... have not had time to go back to the job location....am
going to go back and switch the current transformer from the load side
of the inverter to the line side but in the meantime I was sorta
looking for an answer...
thanks for any replies
