Current Source
Discussion in 'Electronic Basics' started by [email protected], Dec 23, 2013.
  1. Guest
  2. Not sure what node you are referring to, so I will assume it is #4 which
    is the op-amp output node.
    Transistors have an average band gap of ~650mV at room temperature and
    it should be 650 mV more than what is at the emitter.
    With that, you should be able to construct the rest. Good luck with
    your home work.
    Jamie
