K
kell
Looking for a little help with a simple voltage regulator I'm building
for an antique vehicle with a DC generator.
The armature puts out a current that goes through a blocking diode in
the regulator, into the positive terminal of the battery. I need to
limit the current to 10 amps.
If I just string the b/e junction of a bjt across a sense resistor,
then the resistor would have to dissipate 6 or 7 watts during current
limiting. I don't want to use a bulky sense resistor and develop that
much extra heat so I'm looking for a scheme that will use a sense
resistor with a lower voltage drop across it. Any ideas?
P.S. I have to put the sense resistor between the armature and the
battery positive because the ground connection of the voltage regulator
will carry only the field current, not the current from the armature.
The charging current from the armature goes through the chassis and the
ground strap attached to the battery's negative terminal.
Thanks in advance, Kell
