Jamie Morken
Hi all,
I recently found a current sensing chip (LM3814
http://www.national.com/pf/LM/LM3814.html) that can measure the current in a
signal (1Amp or 7Amp range) and outputs a PWM signal proportional to the
signal. This is pretty cool, but I was wondering if anyone has found a chip
that can do this but has a serial interface instead?
The way I have been measuring current before this is to use an
instrumentation amplifier with a dual rail supply hooked up to a shunt from
http://www.isotekcorp.com/ This takes up an ADC input on the
microcontroller and requires more chips and board space.
The current is 500mA max at 5V and 12V.
cheers,
Jamie Morken
cheers,
Jamie Morken
