Current reversal in push/pull?
Discussion in 'Electronic Design' started by Jeffery Dean, Sep 18, 2005.
  1. Jeffery Dean
    Jeffery Dean Guest
    I have an app where I am driving a solenoid using a dual op amp in
    bridge configuration to double the effective voltage from a single
    positive supply.
    In terms of current flow, can someone please clarifiy how this is
    different from using a single amp?
    I need the emiited field to be unidirectional and not reverse.
    Is this possible with a push/pull driver?
    Thank you,
    Jeffery
  2. Fred Bloggs
    Fred Bloggs Guest
    The bridge drive alternates the polarity of voltage across the solenoid-
    so the current will attempt to reverse. If you put the solenoid inside a
    full-wave rectifier bridge with (+) and (-) terminals connected to
    solenoid and AC terminals connected to opamp outputs, then the voltage
    doubles and is rectified- but you lose two diode drops.
  3. Phil Allison
    Phil Allison Guest
    "Jeffery Dean"
    ** HUH ???
    Scotty needs to hear about this.
    ........... Phil
  4. Pooh Bear
    Pooh Bear Guest
    Actually, your push-pull ( actually a bridge configuration ) is used
    quite specifically in order to be able to reverse current flow. It
    doesn't actually double the voltage available, merely offers a
    bi-directional output.
    Single output gives a swing of 0 to Vsupply.
    Dual output gives 0 to +Vsupply or -Vsupply.
    Tie one connection to the solenoid to ground or supply ( whichever
    makes most sense ). Drive it from one op-amp only.
    I hope you have catch diodes on the op-amps output to deal with the
    inductive 'flyback' pulse when the solenoid is de-activated btw.
    Graham
  5. Fred Bloggs
    Fred Bloggs Guest
    You can try this- assuming any other problems- there is no diode drop:
    View in a fixed-width font such as Courier.
    .. 2V
    .. V | |
    .. -- -- | >-|>|---+-KKKKKK--+----+
    .. +--[R]-+-[R]---+
    .. gnd
  6. I canna repeal the laws of ffisiks..........
    martin
  7. Pooh Bear
    Pooh Bear Guest
    The voltage *does not* double !
    A single driver will product a drive voltage = Vsupply.
    A bridge will produce a drive voltage of Vsupply or -Vsupply.
    A bridge driver arrangeemnt with rectifier bridge will produce a drive
    voltage of Vsupply - 2*Vf. I.e. *less* than the single driver.
    Graham
  8. Fred Bloggs
    Fred Bloggs Guest
    Maybe we're taking about two different things- the differential voltage
    across the solenoid is 2x the voltage drive of the op-amp pair: one
    output goes to Vin and the other to -Vin, this makes a magnitude of
    2xVin across the solenoid. A safe way to do this is:
    .. 2V
    .. V | |
    .. -- -- | | >-|>|---+-KKKKKK--+----+
    .. +------------------[R]-+-[R]---+
    .. gnd
  9. Fred Bloggs
    Fred Bloggs Guest
    I suppose if he is just railing them out- this will work well too:
    .. 2V
    .. V | |
    .. V | | >--+
    .. 2
  10. Fred Bloggs
    Fred Bloggs Guest
    Make that :
    .. 2Vdd- some things
    .. V Vdd | |
    .. | | -Vdd |
    .. V | | >--+
    .. 2
  11. Pooh Bear
    Pooh Bear Guest
    Your circuit understood. I 'assumed' that the OP was driving the op-amps to
    rail ( which would make sense ).
    In any event the gain can be simply increased - if that's what's needed - by
    adjusting the feedback but a newbie might indeed not realise that.
    Usual problem - not enough detailed info from OP.
    Regards, Graham
  12. Fred Bloggs
    Fred Bloggs Guest
    I just noticed he said a *single* positive supply-"I have an app where I
    am driving a solenoid using a dual op amp in bridge configuration to
    double the effective voltage from a single positive supply." So he's
    sunk. I can't even understand them half the time- the basis for their
    question is so off-the-wall they are unintelligible.
  13. Pooh Bear
    Pooh Bear Guest
    If we knew the relay voltage and the supply voltage it would make more sesne.
    As you say, with a single supply there's a limit to what's do-able here.
    Graham
  14. Not as funny, now that James Doohan is dead. :(
  15. I read in sci.electronics.design that Michael A. Terrell
    I don't agree. For a public figure to be remembered with affection can't
    be bad.
  16. I disagree, Scotty, did one hell of a lot for getting youngsters
    interested in engineering. I hope that he would be happy for people to
    use his quotes.
    martin
  17. Ditto for non-public figures ;)
  18. We've been here before Fred, a year or so ago.
    A transient capacitive voltage doubler, generating
    2xVs to pull the solenoid in, dropping back to 1xVs
    for holding.
  19. Tony Williams wrote...
    Nice. I handed my technician a design for a box with ten
    small microwave relays -- except the crazy relays want tight
    connections I suppose, and each one takes 5W of coil power!
    That's 50W for the set, and it's got me worried about heat.
    I can't add a fan, because it's going on a quiet optics bench.
    My tech's waiting for parts, so I've got a few days to improve
    the coil-power scene.
    Tony, did you come up with a slick circuit?
  20. Yea Tony, let's see that X2 relay driver again. I can do it with a FET
    bridge, diode and 2*V storage cap but yours was much slicker.
    Regards,
    Harry
