Current Regulator
Discussion in 'General Electronics Discussion' started by Omran65, Apr 10, 2017.
  1. Omran65
    Omran65
    7
    Apr 10, 2017
    hi
    I have a question :
    I want to make current regulator
    LM317 can't work because the voltage of my circuit have be same in output and input
    Vi 14v
    Vo 14v
    Io 0.1A
    can you help me?
  2. davenn
    davenn Moderator
    13,502
    1,830
  3. (*steve*)
    25,306
    2,738
    Current regulators require something to sense the current. Most methods of doing this will incur some voltage drop, even if it is only 0.1V.
  4. Omran65
    Omran65
    7
    Apr 10, 2017
    you guess when my output current is 0.1A my voltage is be lower than 13v?
  5. Omran65
    Omran65
    7
    Apr 10, 2017
    I have output voltage of my circuit is be higher than 12.5v anyhow
    can you proposal simple circuit to me?
  6. (*steve*)
    25,306
    2,738
    Take a look in the LED resource. There is a simple constant current source that can drop less than 1V. For lower drops you need more exotic circuits.
  7. Alec_t
    Alec_t
    2,760
    735
    Jul 7, 2015
    By 'current regulator' do you mean a controllable constant-current source or a current-limiter?
  8. Omran65
    Omran65
    7
    Apr 10, 2017
    l have to use this circuit for very slow charging solid battery
  9. Alec_t
    Alec_t
    2,760
    735
    Jul 7, 2015
    What battery chemistry? Lithium batteries are very fussy about their charging regime. A dedicated battery charge control IC might be better/safer than just a constant-current source.
  10. BobK
    7,674
    1,685
    Your question, as stated is asking for something impossible. You cannot have a current regulator that has an output of 14V and 0.1A. To regulate current, the voltage must vary depending on the load. Perhaps you really mean that the output voltage must be capable of going all the way up to the the supply voltage if necessary. This is called the compliance voltage.
    As others have said, you cannot even measure the current without some loss of voltage.
    If what you want is 14V in and and current regulator all the way up to 14V, you will probably need to boost the voltage first, then run it through a current regulator.
    Omran65 likes this.
  11. Omran65
    Omran65
    7
    Apr 10, 2017
  12. Alec_t
    Alec_t
    2,760
    735
    Jul 7, 2015
    The link doesn't work.
  13. Omran65
    Omran65
    7
    Apr 10, 2017
  14. Bluejets
    Bluejets
    3,787
    783
    Oct 5, 2014
    I've used a standard plug pack (transformer type, not switchmode) 12v 500ma supply via an adjustable LM317 current regulator for different applications for years.
    The supply outputs more than 12v with varying loads naturally, but just trying it now on a fully charged (via another auto charger yesterday)12v sealed lead acid 7Ah battery, it will still deliver 40mA at maximum adjustment on the pot.
    So I think your 1.3Ah battery should be ok with something along these lines.
  15. Omran65
    Omran65
    7
    Apr 10, 2017
    This circuit should be OK?
  16. duke37
    duke37
    5,301
    740
    Jan 9, 2011
    You have shown a voltage regulator, I thought you needed a current regulator.
  17. (*steve*)
    25,306
    2,738
    This will limit the current:
    Assuming the regulator variable with a nominal 1.25V output:
    Vout at 0A is 1.25 * (R1 + R2)/R2
    Iout (short circuit) is 1.25/R3
    There is a linear relationship between these points.
    If you're planning to charge a 12V lead acid battery, I'd set Vout as 14V and Iout as maybe 1A
    Omran65 likes this.
