Current monitor max "vout" = ?
Discussion in 'General Electronics Discussion' started by eem2am, Sep 11, 2013.
  1. eem2am
    eem2am
    414
    Aug 3, 2009
    Hello,
    This concerns single supply operation of LT1787 as in figure 8, page 12 of the datasheet.
    The LT1787 current monitor, on page 3 of its datasheet quotes "vout" as "v(bias) + 1.024V" if "Vs+ > 3.3V".
    Why does "Vs+" have to be greater than 3.3V?
    Surley LT1787 can produce vout = v(bias) + 1.204V if "VS+" = 2.5v?
    (assuming v(bias) = 0V.
    Further down the page on page 3, "VOmax" is stated as VS+ -0.75v.
    So why are they saying that "vs+" has to be greater than 3.3V for "vout" to be 1.024V?
    Surely if "Vs+" is just 2.5v, then "vout" could be 1.024V ?
    LT1787 DATASHEET:
    http://cds.linear.com/docs/en/datasheet/1787fc.pdf
  2. (*steve*)
    25,271
    2,718
    I can't say why, but they are telling you that.
    Perhaps the generation of the internal reference voltage requires a little over 2V of headroom?
    Perhaps you could do your own tests to see if it works at a lower voltage.
  3. eem2am
    eem2am
    414
    Aug 3, 2009
    I am wondering if its actually possible for "vout" to be 1.024V if "vs+" is just 2.5V.
    I see your point, but even if I order one and it does give vout=1.024v at vs+=2.5v, -if the datasheet doesn't corroborate this, then i'll be worrying if the next batch of LT1787 will behave so well?
  4. (*steve*)
    25,271
    2,718
    Exactly.
    And that's why you stay within specified limits. You have a far higher degree of certainty that what works will work next time.
  5. eem2am
    eem2am
    414
    Aug 3, 2009
    I am just wondering what is the guaranteed maximum achievable value of "Vout" if "vs+" is just 2.5v?
