K
Karl Bongers
Hi Everyone,
I'm looking for a way to add current limit to an existing power supply
so I can use it on protos or breadboarding without worrying too
much about blowing things up. Mostly I'm interested in low
current stuff, up to 100ma for example.
At work we have some fancy power supplys that you can set the current
limit on, very nice. I've often wanted to build my own, but never
find the time. One thing I use all the time is just a DC power pack
with a 7805 soldered on and some wire out to my breadboard.
I'm thinking a pchannel mosfet in series with a power supply could
somehow work? Measure the drop across it somehow? Trip the mosfet
to off? Is that called a crowbar circuit?
I needed 12v/5v the other day, extended my PC power supply out
and put a couple small 4 ohm resistors in series. Figured it
would be better to burn these up on rather than
arc weld with my PC. Kindof a cheap fuse, but I hate fuses,
you never have the right size no matter how many you have.
Any idea?
Any idea?
