Curious longlived battery
Discussion in 'Electronic Repair' started by [email protected], Nov 26, 2011.
  1. Guest
    ca 1995 I bought some 7yr diver watches from Woolworth. WHen they doed I
    tried to replace the battery but the entire watch was sealed in silicone and
    could not be salvaged. I had tied one of those watched to the handlebar of my
    bicycle, face towards the sky. It still runs. Is it because the battery
    remained flat? It is kinda miraculous!
    Vasos Panagiotopoulos, Columbia'81+, Reagan, Mozart, Pindus, BioStrategist
    http://www.panix.com/~vjp2/vasos.htm
    ---{Nothing herein constitutes advice. Everything fully disclaimed.}---
    [Homeland Security means private firearms not lazy obstructive guards]
    [Urb sprawl confounds terror] [Phooey on GUI: Windows for subprime Bimbos]
  2. "Normal" is a matter of opinion. I've owned watches that use coin cells.
  3. "Normal" is a matter of opinion. I've owned watches that use coin cells.
    They were lithium. Single cells. To be honest, I've never seen a
    silver-oxide coin cell -- only button cells.
  4. IanM
    IanM Guest
    I've got a Casio [248] W-750 ALARM CHRONOGRAPH wristwatch I've been
    using since the mid '80s. Its on its 5th or 6th replacement lithium
    coin cell. Can't remember whether its CR2032 or CR2025 - the latter I
    think as I keep the former in stock for motherboards. Still working
    reasonably well, though the time setting gets glitchy with a fresh battery.
  5. Jeff Layman
    Jeff Layman Guest
    At the end of 2007 I replaced a Toshiba AAA battery (alkaline manganese)
    in a
    desktop clock-calendar (12.5 mm LCD display), which was given to me in
    1983. It was not new then, as it had already been working for at least
    12 - 18 months.
    Just before I removed it, I measured its on-load voltage (if you can call 1
    microamp a load!) as 0.956 volts. For comparison, the current with a new
    replacement battery was 1.9 microamps.
