Hi. I have a problem with a Datamax M-4206 barcode printer. When the printer is working for a certain period of time the users are not able to print. Even the feed function is not working. If I closed the machine and restart it immediately while holding the PAUSE button to enter in the configuration mode nothing happens, the machine act like if the power were stayed on. But if I shut-off the printer long enough, more than 30 minutes, everything is working correctly.
Did someone have an idea because the first look doesn't shows anything wrong and I don't want to replace everything in the machine.
Thnak you very much.
