CTR of opto-coupler at low diode current (IF)?
Discussion in 'General Electronics Discussion' started by eem2am, Mar 1, 2011.
  1. eem2am
    eem2am
    422
    Aug 3, 2009
    Hello,
    Can i please confirm that even though the CNY17-2 opto-coupler has a stated CTR of 63% to 125%, .....this does not apply at all levels of diode current?
    For example ,Figure 5, page 5 appears to show that the CTR of CNY17-2 is just 30% at a diode current (IF) of 500uA ?
    So do you agree that at low diode currents, the stated "63% to 125%" CTR is meaningless?
    CNY17-2 DATASHEET:
    http://www.vishay.com/docs/83606/cny17.pdf
  2. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    The stated 63% to 125% CTR applies only to a single point on the graph in Figure 5. The graph shows that at If=10mA the CTR is 95%, but it could be as low as 63% or as high as 125%. The graph also shows that the CTR is significantly less at reduced diode current.
