Was the old fly arcing ? If so it probably damaged the video circuit.
The way PIP is accomplished in alot of sets makes it immune to ABL,
which is the path by which the fly can do any damage. Even more common
is the OSD not being affected by ABL.
With a print you're looking for the pin of the fly at the bottom end of
the high voltage secondary. Without a print you're looking for a pin on
the fly with a cutout in the PC board to isolate it. This is so if the
fly secondary arcs it won't cause a carbon track on the PCB and it also
lessens the possibility of fire. There should usually be a reasonable
positive DC voltage there. Some older sets would have the B+ on that
pin and be resistored down for control of the video, but newer sets use
dynamic ABL that is not clamped in normal operation. If you see 0V or a
negative voltage there you are very close to the problem.
Once you run it down and get your video back, view a high contrast fast
moving scene with the picture cranked. You might even want to
temporarily crank up the sub contrast, which you of course return to
the old setting when you're done.
What you are looking for then is compression and rarification of the
raster lines. This dynamic ABL is used for sweep correction. On a
direct view it usually goes to the vertical and video. Some projection
sets also send it to the E-W pincushion as well and sometimes the
integration network is a bit complex.
If you lack a print, get the datasheet for the jungle (LA7612 ?) and
work back from there as well. While you might have a shorted cap near
the fly (in the circuit) it is also possible it zapped something that
either amplifies or buffs the ABL line. The first check I would do is
the resistance from the ABL pin to ground. If it's shorted start
unsoldering stuff from it, or if you happen to have a low ohms meter
you can find it that way.
In a nutshell, I'd say it's a 99% chance or better that the problem is
in the ABL somewhere. I'd go there unless you don't have sync. In case
you don't know how to test for sync, the OSD will move if you remove
the input signal. Just FYI if you don't have any OSD you turn up the G2
so you can see retrace lines and watch their behaviour when you apply
or remove a valid video signal. You might not have to even bother, if
the PIP image is stable you got sync usually.
I hope I pointed you in the right direction, good luck.
JURB
PS ; I gotta try to help you save this beast, have you seen the new
shit they're building ? What a nightmare.
JURB
