CTC197 - LA7612N info needed
Discussion in 'Electronic Repair' started by Ben, Mar 6, 2007.
  1. Ben
    Ben Guest
    Hi ,
    Having a RCA F32683SB (CTC197CE2) with a vertical problem. Had a few
    other problems before like a bad flyback but it's OK now.
    The remaining problem is in the vertical and it seems to come from a
    jungle IC LA7612N (Sanyo) that I cannot get the datasheet.
    Any idea where I can get it ?
    Tks...
  2. Guest
    Would you settle for a def print ? I have it on cd. give me a mail
    address
    C Grob
  3. Ben
    Ben Guest
    What is a def print ?
  4. Guest
    SCHEMATIC OF THE DEFLECTION CIRCUIT. SEND MAIL ADDRESS & I'LL MAIL
    IT C GROB
  5. Ben
    Ben Guest
    Hi , did you get it ?
    Tks.
