M
moonlite
Hi- I have a CTC185AB4 chassis. The 5 amp. fuse was blown, the HOT was
shorted as well as the regulator Q4114. My testing of the Flyback is
inconclusive. I installed the regulator kit, but I'm afraid to turn it
on and blow everything up again in case the Flyback is bad. Can anyone
suggest a safe way to test the set without losing all these parts I put
in ? Will turning it on at a reduced AC voltage do the trick ? Thank
you
moonlite
you
moonlite
