B
Bill
Hello all- I have a CTC187 chassis that is completely dead. voltages
on the STK regulator are perfect. Pin 8 of the eeprom has 5v. However,
pins 5 and 6 have only 3 and 2.7 volts respectively, even with the
eeprom removed. Could this possibly be my problem ? I believe those
pins should be around 5 volts each. If so, does anyone know what can
cause the voltage here to go low ? I hate to replace the micro unless
I'm certain it is the problem. Thanks.
