crystal oscillator question...thx
S
Sommes
How to adjust the oscillation frequency from the output frequency of 1MHz
crystal oscillator?
N
Norm Dresner
crystal oscillator?
Do you want to adjust it so it'll be 1 MHz or something else? Over what
range do you want to adjust it? Oh, and by the way, what kind of oscillator
circuit are you using?
C
colin
crystal oscillator?
A variable capacitor, or varicap diode in series with one of the capacitors
wil give you upto a few 100ppm adjustment depending on crystal.
a PLL will alow u to adjust it in discrete jumps, or u can just divide it by
any binary number with a pre setable counter
or multiply witha mixer/multiplier to get twice the frequency, or filter out
the 3,5 harmonics etc.
Colin =^.^=
S
Sommes
I am doing a analog project.
The topic: High stability variable oscillator
Select and test an appropriate digital oscillator circuit for producing an
accurate variable oscillation from 1kHz to 1MHz
What I think is I have to use crystal oscillator to make stable oscillation.
I will chose 1MHz crystal oscillation...after I may need to adjust 1MHz to
1KHz range.
Please let me know the right track...Thanks...
T
Tim Wescott
1KHz range.
Crystal oscillators are quite stable, but you pay for that with a very
narrow frequency range. Pulling a crystal oscillator by +/- 1000ppm is
a lot; pulling it by 3 orders of magnitude is simply out of the question.
It sounds like you're doing a school project.
I suggest you get a copy of the ARRL handbook. What with oscillators
being of core importance to radio design it has a lot of practical
cookbook kind of information on this topic. Wes Hayward's "Introduction
to Radio Frequency Design" wouldn't be out of place if you decided on an
LC oscillator.
Here's some suggestions for how you can pull this off:
1. Find out what "High stability" means in the context of your project
definition. One man's "High stability" is the next one's "jittery piece
of crap"; the threshold value for this has a huge impact on how long
you're going to spend.
2. Ask what is meant by "digital oscillator"? I assume that means
digital output, what else does it mean?
3. Ask what is meant by "variable" - continuously variable? Variable
in discrete steps? How big can the steps be?
4. Find out if you have any other constraints -- output level, spectral
purity, etc.
5. Finally, there are a number of oscillator topologies that you may
want to look into. Depending on the answers to the questions above you
will want to look at:
* RC oscillators (linear or multivibrator),
* LC oscillators (i.e. Colpitts, Hartley, etc.),
* NCOs (numerically controlled oscillator) or
* phase-locked loops (with RC or LC oscillator core).
You can find information on any of these on the Web. Any of these can
have the range extended by building an oscillator that goes from 500kHz
to 1MHz and doing a series of divide-by-two operations to get down to
1kHz.
P
Paul Burridge
Well if you mix it and filter, you could get *any* other frequency,
not just a multiple or a discrete step!
T
Tam/WB2TT
oscillation.
1KHz range.
You are going to divide the 1 MHz by 1000 to get 1 KHz, right?
Tam
G
Gareth
How can you do that (unless you have another variable oscillator to mix
it with, which seems a bit pointless)?
Gareth.
G
Gareth
1KHz range.
You say it is an analog project? I think that would rule out things
like Phase Locked Loops (PLLs) and synthesizers.
One easy way to get a frequency which is variable from 1KHz to 1MHz
would be to use a 555 timer. This will be nowhere near as accurate as a
crystal but it may be accurate enough for your project. I don't know,
but have a look at:
http://www.doctronics.co.uk/555.htm
Another option would be to use an oscillator IC, e.g LTC6900, which can
be adjusted from 1 KHz to 20 MHz. See:
http://www.linear.com/pc/productDetail.do?navId=H0,C1,C1010,C1096,P2186
Again this is nowhere near as accurate as a crystal, but may do what you
want.
Gareth.
N
Norm Dresner
See comments in-line
Not really. Starting with a square wave it's moderately easy to create
a triangle and not all that hard to approximate a sine wave either. There's
really nothing much like a PLL to get accuracy (but not necessarily
short-term precision). Or Direct Digital Synthesis. DDS is expensive but
it'll put out very nice sine waves of rather controllable frequencies.
but have a look at:
For accuracy, nothing beats a crystal -- unless it's a better crystal or an
atomic clock which, I'm pretty sure is out of the OP's budget. But the
question of accuracy may be a red herring. It might be sufficient to have a
555 with a digital frequency readout and a 10-turn pot for time setting. Of
course, that doesn't produce very good stability. And if it's an analog
output that the OP really wants directly from the oscillator then the 555's
binary output isn't what would get him a good grade.
What about the venerable "Intersil" 8038 (or whoever makes it these
days) or one of the Exar things like the (IIRC) 2240 which has it's own
binary divider.
want.
Norm
P
Paul Burridge
Exactly, but there are times when it's necessary to do this and it is
in fact pretty much 'de rigeur' in most radio circuitry.
T
Tam/WB2TT
Gareth said:
How can you do that (unless you have another variable oscillator to mix it
Gareth.
To reply to me directly:
Replace privacy.net with: totalise DOT co DOT uk and replace me with
gareth.harris
This is used to get a wide range oscillator. For instance, the HP 8601 used
something like a 300 MHz xtal osc and 300 - 400 MHz VCO to get 1 - 100 MHz
output. Highly unstable; primary use was as a sweep generator.
Tam
C
colin
producing 1MHz
binary divider.
Norm
if you can say what sort of acuracy you need and what is used to set the
frequency (ie a voltage or binary number etc) we might be more able to help.
Colin =^.^=
C
colin
Tam
You can use a mixer as a multiplier is what i was sugesting. ie u feed the
same signal into both input ports and get 2x frequency out +dc.
a good way to get a wide range VCO is to use a ring of 3 amplifiers with
programable bandwidth and adjustable gain in the region of -1.5. each one
introduces 60' phase shift at its uper frequency and this cuases oscilation
due to 180' phase shift negative feedback. the bandwidth and hence
oscilation frequency is a function of bias curent and this can be varied
over a very wide range.
im trying to make one for vhf/uhf, i have a ring of 3 mosfets fed from
constant curent sources, biased to about 1.5 v vds to reduce the gain to
about 1.5. At the moment it wil oscilate wel over 100mhz and 200mhz shld be
posible and if you take the sum of al three amplifiers the distortion gives
you a 3x multiplier so should see 600mhz. trying to keep
capacitances/inductances down enough is dificult using discrete components.
the lower frequency is probably determined by how well the MOSFETS are
matched.
Colin =^.^=
