Crystal oscillator 15pF load
Discussion in 'General Electronics Discussion' started by CommanderLake, Nov 14, 2019.
  1. CommanderLake
    CommanderLake
    199
    6
    Oct 2, 2012
    How can one verify a crystal oscillator has a 15pF load if any kind of testing equipment such as a scope probe adds capacitance to it, it seems impossible to verify the waveform without modifying it?
  2. bertus
    bertus Moderator
    2,070
    780
    Nov 8, 2019
    Hello,
    What schematic do you use?
    For what application is the oscillator?
    Bertus
  3. CommanderLake
    CommanderLake
    199
    6
    Oct 2, 2012
    I have a Connor-Winfield OH4610LF-024.576M
    Its not a question relating to any particular application, the datasheet says 15pF nominal load so hypothetically how does one verify such a small load if a scope probe tip is 15pF?
  4. bertus
    bertus Moderator
    2,070
    780
    Nov 8, 2019
    Hello,
    With the 15 pF load, you probably mean the test circuit in the datasheet:
    The load is only there to show the driver capability.
    Measuring the output to show the rise and fall times of the signal.
    Bertus
  5. CommanderLake
    CommanderLake
    199
    6
    Oct 2, 2012
    Page 3, parameter Load: 15pF nominal.
    How is it possible for one to validate such a small load?
  6. majoco
    majoco
    50
    8
    Nov 10, 2019
    IMHO the load affects the waveform - 50ohms load makes the output into s a sine wave, 15pF might preserve a square wave shape.
    As in most things - one test is worth a thousand opinions. ;)
