crt tv horizontal display problem
Discussion in 'Troubleshooting and Repair' started by walid ahmed, Aug 12, 2017.
  1. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    The crt tv cant display horizontally. The HOT and yoke coils are ok.....when horizontal yoke coil connected then the tv dont turn on...when removed then it ONs.
  2. davenn
    davenn Moderator
    13,865
    1,956
    things like the make and model of TV would be really helpful if you want some one to help you
    have you googled for service manual or at least a schematic ?
  3. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    the model of the pcb is ZR-818B-PCB a chineese normal commercial pcb
  4. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    We need the make and model of the TV set, not the pcb.
  5. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    i replaced with best HOT. and driver transistor also...but when horizontal yoke connected only then tv didnt turn on
  6. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    the tv set is different with the pcb.....a different crt and universal chineese pcb there
  7. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    so the tv model will not do to identify the present pcb connected
  8. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    Without a schematic to reference to what do you expect us to advise? Or should we just guess? I can't find any reference to match the details you have already given. Unless you can show us a picture of the board or the diagram we're pretty much in the dark.
    Have you checked the sync pulses to the board?
    walid ahmed likes this.
  9. debe
    debe
    269
    71
    Oct 15, 2011
    I guess if you are using a PCB that wasn't meant for that deflection yoke then theres a mismatch, & it wont work
    davenn likes this.
  10. davenn
    davenn Moderator
    13,865
    1,956
    thread closed
    @walid ahmed when you are able to supply make and model of the TV you are working on
    PM me and I will reopen the thread
    There is no point in all of us playing 20 questions if you are not going to supply the needed info
  11. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    Ok dear...i failed to give u any info about the tv....close the thread and just tell if the horz shorted yoke can prevent the tv to turn on?
  12. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    If the horizontal yoke is shorted it will cause an overload of the power supply and shut the set down.
  13. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    You r great!!!!thanks sir.
  14. walid ahmed
    walid ahmed
    9
    Aug 12, 2017
    Can it cause the picture tube to dont turn on?
  15. shrtrnd
    shrtrnd
    3,823
    519
    Jan 15, 2010
    If the filament at the neck of the picture tube lights-up, the picture tube is on.
    The yoke is a separate circuit.
  16. 73's de Edd
    73's de Edd
    3,121
    1,315
    Aug 21, 2015
    Sir walid ahmed . . . . .
    You say . . .
    This pic below is showing a problem with the sets HORIZONTAL CIRCUITRY or the yoke
    A quite rarely occurring condition . . . . .
    [​IMG]
    If you have the MUCH MORE COMMON problem, where the bright white line will be ACROSS the screen from left to right, instead of UP and DOWN, as is shown in my 1st picture.
    THAT will be a VERTICAL problem.
    Now which is it.?
    Also, does the sound always remain on ?
    You say . . .
    Are the hoz and yoke connections being SEPARATE . . . . two pin . . . . plug in connectors ?.
    73's de Edd
