James Lerch
Greetings All,
Just picked up a lot of 60 Crouzet 50 amp solid state relays on Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3818024478&sspagename=STRK:MEWA:IT&rd=1
While I don't have a use for ALL 60 yet, I plan to use at 6 of them to
add computer control to a 6 element electric ceramic kiln. The kiln
draw ~50 amps at 220Vac when all 6 elements are on "high"
The goal for the project is to be able to perform fine annealing on
various glass wares, specifically glass telescope mirror blanks. My
current idea is to install one SSR per heating element. The
temperature control is based on a K-Type thermocouple monitored by the
control computer, which will cycle the SSR's on/off with a frequency
of 5 seconds.
My first question is "Will I need to include a heat sink?" Each SSR
will only switch a single element at 9amps @ 220vac.
Second question, will I need to include any ancillary support
electronics? I plan to trigger the SSRs off a computer printer port.
In previous adventures with printer ports, I've used an 8 bit line
driver between the printer port and the stuff I manipulate. The specs
for the SSR indicate the DC side is optically isolated and only draws
10mA. This bodes well for direct control via a printer port. While
on the topic of ancillary electronics, will I need / want to include a
pull down resistor across the DC control inputs on the SSR? I ask as
I found out the hard way that strange things can happen with inputs
left in a 'floating' state.
My last question is unrelated to the kiln control project, "Are there
any loads I should not be switching On/Off with an SSR? "
Specifically, can I switch large inductive loads?
Finally, for those that will be concerned with safety oriented ideas,
here's a short list of steps I plan to include to prevent burning my
shop to the ground.
#1 The Kiln already has a "Kiln Sitter" installed, which will remain
active as part of my 'upgrade'. The kiln sitter consists of two
devices.
A) A 20 hour timer, normally set to a value larger than the
anticipated firing time. Since my firing times will exceed this
value, I'll have to manually reset it every so often.
B) A pyrometric cone, usually selected to achieve the firing
temp desired during normal ceramic work. In my application, I'll
select a cone that will be slightly higher than my anticipated target
temperature. In the event of a failure causing the kiln to be left in
an on state, the pyrometric cone will shut the kiln down.
#2 I also have several software safe guards included.
A) The computer controlling the kiln is on a network, and logs
its data and status to a separate computer.
B) The monitoring computer is able to alert me via an audible
alarm and my digital pager, in the event the controlling computer
doesn't respond, or the kiln temperature exceeds some threshold.
I guess that's all my questions for now, comments and suggestions are
greatly appreciated!
Take Care,
James Lerch
http://lerch.no-ip.com/atm (My telescope construction, Testing, and Coating site)
Press on: nothing in the world can take the place of perseverance.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent.
Calvin Coolidge
of 5 seconds.
shop to the ground.
devices.
Take Care,
James Lerch
Calvin Coolidge
