cross ref to CY7C371 ?
Discussion in 'Electronic Components' started by EN, May 13, 2005.
  1. EN
    EN Guest
    Is there a cross ref to the cypress flash part, 44 pin plcc ?
  2. Eric Smith
    Eric Smith Guest
    It's a CPLD, so you can't replace it with another part unless you
    can program the same bits into it.
    AFAIK, there isn't any second-source for the CY3C37x series.
  3. EN
    EN Guest
    I just found a AMD MACH110, which is suppose to be a replacement.
    I found that Cypress has a 7c371i version. Don't know the difference
    between the ' non-i ' and the ' i ' part yet. Still looking for a
    datasheet.
    thanks
    Ed
  4. Eric Smith
    Eric Smith Guest
    The "i" parts are the in-circuit-programmable ones.
