Harbin Osteen said:
daestrom:
I did not crosspost,
And that is exactly my complaint. You didn't 'crosspost', you
'multiple-posted' instead. Learn what the difference is and then you'll
understand why crossposting to *relevant* groups is a *good* thing.
I'm not saying your project is *not* relevant to alt.energy.homepower,
merely that by using 'multiple-posting' instead of 'crossposting', you're
exact same message has popped up in my newsreader multiple times. I only
need to read it once. Almost any newsreader (even OE) will allow marking a
message that is crossposted as read the *first* time I read it, so I don't
have to keep-re-reading it again and again.
But by 'multiple-posting', newsreaders cannot tell that the message in
several groups is the exact same thing, so your *multiple-posted* message
just keeps popping up over, and over, and over, and over, and over again in
each of the groups you posted.
If you *had* crossposted, I still would have seen your message, but only
once. And not have to keep seeing the same subject-line/header downloaded
in each and every group that you multiple-posted it on.
Learn the difference, keep it relevant, and good luck.
daestrom
