Blank Stare
- Oct 10, 2012
- 48
- Joined
- Oct 10, 2012
- Messages
- 48
I need help designing a circuit that will take power from a 6v DC battery, and change it to an extremely high voltage, but extremely low amperage ZAP!, to discourage raccoons from destroying a piece of equipment I own, without doing any permanent damage to the raccoons. I think the proper circuit will use electronics to make an artificial sine wave, so that the shock has the desired effect.
Think electronic dog collar, as far as the kind of current specs I want for output. Or you could think micro-horse fence. I have seen some devices on the market designed to do similar duty, that state they have an output of 10,000 to 20,000 volts, but they do not state the amps.
I would buy something ready made, but I need to make it fit inside the compartment that all the rest of the equipment's parts are in, in order to protect it from weather, and the critters.
Ideally, the completed device will be about the size of a deck of cards. It MUST be powered by a 6 volt rechargeable battery, that is recharged by a solar cell elsewhere on the equipment.
The ground output lead from the device will attach to a cage I will be putting around the equipment, and the positive lead will be wrapped around plastic parts that are several inches, to a foot from the cage. A critter reaching through the cage will reach for the object they desire (debris on the automatic corn spreader), and brush against the positive lead. They will then receive a surprising shock, as their arm completes the circuit between the cage and the positive lead wire.
I can not stress enough that this must be non-lethal. As annoying as these little banditos can be, they are not doing anything unexpected... they are just foraging. I even think they are cool creatures - but they are ruining my equipment, and preventing me from my purpose. After they get jolted few times, they will learn to forage elsewhere, and everyone is happy.
I have built, and even designed a few simple circuits. Nothing fancy, and I had help each time. Once I had a schematic for the circuit, I was able to order parts online, and assemble them on my kitchen table.
At the moment, the biggest unknown is how many volts/amps output to design the circuit for. Once that is known, I can start trying to figure out how to size the electronics for the job.
Anyone care to help out?
Thanks in advance.
Thanks in advance.
