Can someone recommend an inexpensive ( < $25) crimper for the connectors on mouser catalog page 888? http://www.mouser.com/catalog/621/888.pdf -- Chris W Gift Giving Made Easy Get the gifts you want & give the gifts they want http://thewishzone.com
There isn't much of a solution other than manually soldering (sparingly) and careful crimping with pliers. If it says AMP, it's going to cost you but it will last. Some 15 years back I got burned with a 30 dollar RJ-45 crimper. After having to redo all crimps except those made to silver satin cable, I bought a $136 AMP crimper. I fail no crimps due to the tool now, only from my allowing a wire to land in an incorrect channel.
Go to Rat Shack or a real electronics store, with a pin if at all possible. Check their tool rack for crimpers. The one you want will look something like this: http://www.neodruid.net/images/crimpers.jpg http://www.neodruid.net/images/crimper-anvil1.jpg http://www.neodruid.net/images/crimper-anvil2.jpg Good Luck! Rich
If you are in the U.S.: Lowes and Home Depot (home improvement stores) has crimpers of many types (not all).
