Crimp connectors
Discussion in 'Datasheets, Manuals and Component Identification' started by Mr Ed, Oct 8, 2017.
  1. Mr Ed
    Mr Ed
    16
    Oct 6, 2017
    Are there any crimp connectors suitable for connecting components (diodes, resistors etc) to stranded wire?
  2. davenn
    davenn Moderator
    13,803
    1,941
    not specifically, that I am aware of
    what are you trying to do and why cant you just solder the wired and put heatshrink over the joint ?
  3. Mr Ed
    Mr Ed
    16
    Oct 6, 2017
    No reason I can't solder it. It's just that there seems to be crimp connectors for just about every situation so I thought I would try them out if possible.
  4. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    They are called barrel crimp connectors, sometimes seen in appliances to join the inline thermal fuse and other purposes etc.
    M.
    [​IMG]
  5. kellys_eye
    kellys_eye
    4,275
    1,147
    Jun 25, 2010
    The crimps shown above might not offer as secure a crimp as you require given they are usually rated for 0.5mm to 1.5mm C.S.A wires.
    There are 'bootlace ferrules' that accept smaller diameter wires but you'd have to cut the 'boot' off and heatshrink the crimped joint.
  6. (*steve*)
    25,482
    2,830
    And for many of the crimping tools for these you'll need to make sure you can get the crimping tool over the component.
  7. Mr Ed
    Mr Ed
    16
    Oct 6, 2017
    Not worth the trouble. I'll just go with solder.
  8. hexreader
    hexreader
    124
    35
    Apr 21, 2011
    No need for cutting the boot off of a bootlace ferrule.
    Just buy ferrules with no boot, such as: http://cpc.farnell.com/pro-power/sten-1008/ferrules-uninsulated-bootlace/dp/CN11650
    Very handy for all sorts of jobs, and uses same crimp tool as booted ferrules
    Not found boot-less ferrules for smaller sizes (0.25 and 0.34) though, so maybe cutting off the boot is still needed here. Admittedly I have not looked very hard.
