I need advice to create a simple circuit idea for a local theater to use. The idea uses two circuits created from two photo resistors, one LED, two batteries (voltage uncertain) and a few light bulbs. I have very little experience with small electronics, but I know if I can iron out the details someone else can make it.My idea is to make a street lamp on stage that is battery powered go on and off with the stage lights.To do this I would use a photo resistor on the top of the lamp post, that would be wired to a (9v?) battery and a LED. The LED would light up when the photo resistor detected the stage lights are out.
The LED would be stuck into the end of a small, short tube (maybe a short piece of a BIC pen). In the other end of the tube would be the second photo resistor. The photo resistor would be circuited to a larger battery and the three light bulbs for the street lamp
That second photo resistor would detect the LED- meaning when the stage is in a black out the street lamp would be out. When the stage lights come up, the street lamp also comes up. There would also be an on/off switch on the second circuit.
I am sure there is a need for capacitors, resistors and voltages. Any help is appreciated
Thank you
Thank you
