Creating Square or sawtooth waves
Discussion in 'General Electronics Discussion' started by Electro132, Apr 25, 2013.
  1. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    I was just playing with a software program that generates different tones (sine, square & sawtooth) and had a think about how these waves are created with components in a circuit
    especially if there was a wide range in hz and an amplification of 0 -1. So i'll take a guess at this: i use a special type of IC for the hz and a trimpot switched fully on (to represent 1) for the amplifier.
    Thoughts anyone?
  2. Harald Kapp
    11,513
    2,651
    There are so many ways to generate different waveforms. From discrete transistor circuits, standard ICs (e.g. OpAmps) , specialized ICs to digital synthesis using µcontrollers.
    You need to know primarily the frequency range. Amplitude of voltage and/or current can be set independently by an amplifier or attenuator.
    Go Google for the circuit you like, come back with detailed questions.
  3. (*steve*)
    25,496
    2,837
    Let me give you a car analogy...
    I was just playing with a software program that shows me different types of vehicles (car, truck, and train)
    and had a think about how these vehicles are made in a factory
    especially if there is a wide range in miles per hour and colour
    So I'll take a guess at this:
    I use a special machine for the miles per hour
    and a screw tightened really tight (to represent potato) for the colour.
    Yes, your thoughts are full of words which don't mean what you think they do.
    An oscillator generates a periodic waveform. The type of the oscillator (and possibly any filtering you apply) determines the shape of the waveform.
    Different waveforms (at the same frequency) sound quite different.
    The frequency (measured in Hz) is determined by component values that cause the oscillator to oscillate at a certain frequency.
    An amplifier makes the sounds louder. An oscillator needs to be able to amplify (so that the oscillations are maintained) but this is just part of what makes it an oscillator.
  4. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Ok thanks Harald & Steve. I have found one which confuses me as there is an fm source on this circuit going into the same component as the battery source. The file is attached.
  5. Harald Kapp
    11,513
    2,651
    Using the pot you adjust the frequenvy manuall. The FM input allows setting the frequency electronically.
    This is most probably not the circuit you're looking for - it uses that TC9400 voltage to frequency converter module.
    You still haven't told us any of your requirements, so we are not able to help you more.
  6. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    here are my requirements and questions:
    - 3 v constant supply current to the waveform generator, the amplifier and the LED circuit
    - An amp that increases the wave form loudness (what components do i need for the output after the amplifier? I'm afraid that the LED which comes after the amplifier will explode or get burnt out if i use a 220 ohm or 150 ohm, will it?)
  7. davenn
    davenn Moderator
    13,833
    1,950
    So you want the generator to be powered by a 3V battery ?
    OK ... so how loud ? will a small speaker 1 to 5W be enough? ... that would be easily heard
    Why on earth would you want to put a LED on the output of the amplifier ??
    its pointless will serve no purpose .... use a speaker as I suggested earlier
  8. Harald Kapp
    11,513
    2,651
    My guess is he's still after his sound on light fantasy.
  9. davenn
    davenn Moderator
    13,833
    1,950
    ahhh maybe ??
