A
Alejandro
Hi Everybody,
This crazy thing happened,
A friend of mine, told me if I could get a look at his minicomponent
system, because the six CD changer was stuck. I'm a electronic
technician, so I said no problem, and opened the equipment, I
dissembled the front of the system, disconnected some cables, and then
reached one CD that was stuck in the mechanism. I then put everything
together, tried the CD , and it worked fine, till my friend asks me,
why did the display didn't worked. This is where the problem really
started for me, I carefully opened the equipment again, verified
everything, and found nothing wrong. There was a flat cable that
connected the front panel with the inside, I thought that maybe one
wire had been cut, so I checked it with my tester, but the cable was
fine.
I did some measurements on the displays pins and found that there was
a 28V in most of the pins. I tried to see if there was something that
was making shortcut, but nothing.
So, the resume is that the CD works ok, but there's no display, also
the radio that is in the same cabinet, doesn't seem to work too.
I don't have the service manual so, I don't know where to go.
THE EQUIPMENT IS A TWO CABINETS MINICOMPONENT SYSTEM.
JVC MODEL CA-C550
Any help would be really appreciated,
Alejandro Katz
fine.
JVC MODEL CA-C550
Alejandro Katz
