Crate BV150H valve amps
Discussion in 'Electronic Repair' started by N_Cook, Feb 9, 2010.
  1. N_Cook
    N_Cook Guest
    Likely a commonly occuring problem on the discrete wire IDC connectors, this
    one 2003. The core and insulation of the screened wire is too thick for the
    IDC metal. Presumably the IDC metal relaxes and only marginal metal contact
    to pass factory tests in the first place. Only light finger force required
    to lift the wire out of the trap. The screening contacts are fine, as just
    heatshrink sleving on them.
  2. N_Cook
    N_Cook Guest
    There are about 10 such screened leads inside , with an IDC on either end. I
    suppose the probability of 1 in 20 failing is quite high.
