CR1632 (3v) vs. Two AA's
Discussion in 'General Electronics Discussion' started by Wolfrado, Apr 6, 2015.
  1. Wolfrado
    Wolfrado
    4
    Apr 6, 2015
    Hey,
    Kind of a newbie at this, so forgive me if this is a stupid question. I've disassembled a small lifeline alert pendant transmitter that normally runs on a CR1632, can I replace it with two AA's? Are there any disadvantages? Do CR batteries last longer, have more capacity than AA's, etc.?
    On a separate note, if I want to replace the batteries with a power supply, can I use a 5v USB supply or would I have to look for a 3v supply?
    Ward
  2. (*steve*)
    25,497
    2,839
    The CR1632 is likely to have much less capacity than a pair of AA cells.
    Yes, I would think that using 2 x AA cells would be OK.
    5V could be too high for the electronics, adding a 3.3.V regulator would make it safe.
  3. Wolfrado
    Wolfrado
    4
    Apr 6, 2015
  4. hevans1944
    hevans1944 Hop - AC8NS
    4,615
    2,154
    Jun 21, 2012
    Why are you trying to "hack" a "lifeline alert pendant transmitter"? If it is being used for its original purpose, you could be making it unreliable for its intended purpose, perhaps putting the user's life in peril. Please tell us you are re-purposing this device for some project that does not involve life-or-death situations.
  5. Wolfrado
    Wolfrado
    4
    Apr 6, 2015
    No one's life is at risk. I'm experimenting with an automated system that uses external sensors to trigger the pendant for individuals who can no longer operate the pendant themselves or who forget to use it. It's more of a proof of concept.
  6. hevans1944
    4,615
    2,154
    Jun 21, 2012
    Then that little power supply should work just fine for your purposes... a heck of lot cheaper than replacing those CR1632 cells. Or you could maybe use a rechargable lithium ion battery...
  7. Wolfrado
    Wolfrado
    4
    Apr 6, 2015
    Thanks for the help. I'll give it a try.
