CPU pin outs...
Discussion in 'General Electronics Discussion' started by cjdelphi, Nov 20, 2011.
  1. cjdelphi
    cjdelphi
    1,161
    108
    Oct 26, 2011
    [title should really be pin in lol]
    I was looking at the range of processors from atmel
    http://www.atmel.com/dyn/products/devices.asp?category_id=163&family_id=607&subfamily_id=2138
    And i was thinking it would be nice if there was any reasonable processors not too fast not too slow which had really good battery life better than ARM's... so i found a 32bit processor from atmel.
    now... if you look there's no support for cam/video but i was thinking would it not be possible to simply feed the output signal from a small cmos/webcam and then via the firmware simply read in the raw data on any of it's io pins?
    thinking about it, it should be possible to do that with the arduino kit in fact using a really basic processor no?
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Hi cjdelphi,
    The AVR32 7000 range have an Image Sensor Interface (ISI) and a Pixel Co-Processor
    Here under the (huge) datasheet
    http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf
    and the driver Application Note:
    http://www.atmel.com/dyn/resources/prod_documents/doc32084.pdf
    Now it depend of what the application is, yes you can connect a camera module on the serial port of an arduino, or any other small 8 bit based board, but performances are limited.
    For higher performances, real time analysis, recognition algorithm... you must more horse power and the AVR32 look's fine for such tasks
    Olivier
