OK so we need a 44 pin LQFP break out board...
NOTE THESE BREAKOUT BOARDS ARE FOR 44 TQFP, they SHOULD work with your chip but without verification of the package size and pitch they might not...
There is one on Ebay
http://www.ebay.com/itm/4x-TQFP-44-...283?pt=LH_DefaultDomain_0&hash=item19cfff5bc3
This one
https://www.sparkfun.com/products/8879
Or this one pull down to the 44 TQFP, don't confuse it with the 48 LQFP that won't work in your case...
http://www.futurlec.com/SMD_Adapters.shtml
Or Google '44 TQFP to DIP' or '44 TQFP breakout' and pick one of many other companies that make breakout boards... But, do note that these are all for standard TQFP and although they should work with your chip... I personally don't have verification that ZoLOG stuck to the same pitch and package size on your particular chip, sometimes companies pull a fast one and make a proprietary modification to the chip layout for whatever reason...
BTW in another thread you asked about soldering a CPU, if this is the chip in question it's a lot easier... This chip can be soldered with an iron carefully, or just a heat gun... No need for fancy stuff if you are only doing one or two...
