P
Paul Burridge
For best long-term reliability, if there is no DC present, you should
use a reversible electrolytic, or two ordinary ones back-to-back, maybe
with some DC bias applied to their junction. But in many cases, just a
single ordinary electrolytic is quite OK. I don't like to use anything
less than 6 V caps, though, in such applications.
ISTR someone on this group stated a while back that if a UK-spec
electolytic is marked at say 16V or 24V or example, that it wouldn't
be much use where there's only a very small DC potential across it.
If your caps are elderly, re-form them by connecting to a DC supply
equal to the marked working voltage and monitor the leakage current.
Again ISTR that the proper way to do this is to slowly turn the
voltage up bit-by-biy from a low level over a period of a few hours...
