Counter ICs
Discussion in 'Electronic Basics' started by Richard, Jun 30, 2011.
  1. Richard
    Richard Guest
    MC14017B
    http://www.onsemi.com/pub_link/Collateral/MC14017B-D.PDF
    I've just begun to look at digital electronics, and of course I have
    come across the 4 bit counter.
    In a 4 bit counter the output is at Q1, Q2, Q3 and Q4. We can feed these
    4 bits (from a decade counter usually) into a decoder to drive a 7
    segment display.
    MC14017B is a 5 stage counter with built in code converter and shows
    outputs Q0 - Q9.
    Is this actually like a 5 bit counter, or what? Thanks.
  2. Jon Kirwan
    Jon Kirwan Guest
    Examine this java-coded display of one:
    http://www.falstad.com/circuit/e-johnsonctr.html
    It's a 5-bit ring, but the output of the last bit is inverted
    and fed back so it takes two loops through to repeat itself
    completely.
    Jon
  3. Jasen Betts
    Jasen Betts Guest
    Hi, you've found a data-sheet that's a really good start.
    actually it's a 5 bit shift register fed back it's inverted output
    then run through a bunch of gates (see page 2 of the data sheet)
    it counts to 10 having one output (Q0-Q9) high for each step.
    It's basically the same chip as the 4017B used here.
    http://www.technologystudent.com/elec1/count1.htm
    not that I'm reccomend that circuit (with a 9V supply) other than as an
    experiment as it's using the LEDS outside of their specifications and
    they may not last very long, it's better to use one resistor for each LED
  4. Richard
    Richard Guest
    Hi. So it's not a 4 digit counter, it's 10 digit counter, and that is
    why we see Q0 -Q9. But there is a 5 shift register in the IC.
    Not sure what the code converter is about though.
    At present what interests me is a decade counter.
    From what I read, for each 7 segment display, you require 4 bits
    representing the count, and you are getting Binary Coded Decimal at
    Q1-Q4 (because we are using decade counters) and not regular binary
    (modulo 16?). So, when building for 7 segment displays you need 4 bits
    for every display. Therefore you would need a 16 bit counter (4 x 4 bit)
    to run four 7 segment LED displays. I guess so.
  5. Richard
    Richard Guest
    I mean 4 bit and 10 bit.
  6. Richard
    Richard Guest
    I've not enough knowledge yet to understand these counter IC's.
    I've just started learning digital, and all I know about is 4 bit
    counters and how you can use those 4 bits (BCD in a decade counter) to
    run a 7 segment display (via a BCD decoder).
    So, when I think about counters with 7 segment displays, I'm assuming
    your counter must be 4 bit, 8 bit, 12 bit etc.
    I think this is true except for ring counters.
    I just don't know why, with a decade counter, there are 10 bits in the
    IC MC14017B-D and not multiples of 4bits.
  7. Am 30.6.2011 schrub Richard:
    They just use different codes:
    the 4 bit counter outputs a base-2 code while the 10 bit counter outputs
    a 1-out-of-10 code:
    base-2 1-out-of-10
    0000 0000000001
    0001 0000000010
    0010 0000000100
    0011 0000001000
    0100 0000010000
    0101 0000100000
    0110 0001000000
    0111 0010000000
    1000 0100000000
    1001 1000000000
    The 1-out-of-10 counter could just as well be implemented using a base-2
    BCD counter (e.g. an SN74LS160A) and a decoder (e.g. an SN74LS145).
    Josef
  8. Am 30.6.2011 schrub Richard:
    It must be a decoder which outputs a special code, as a simple "BCD
    decoder" will output a 1-out-of-10 code. What you need is one that
    outputs a code geared towards 7-segment displays:
    Input Output
    0000 1110111
    0001 0100100
    0010 1011101
    0011 1101101
    0100 0101110
    0101 1101011
    0110 1111011
    0111 0100101
    1000 1111111
    1001 1101111
    The least significant bit of the output is the top horizontal bar, then
    the more significant bits are arranged from top to bottom and from left
    to right:
    |1 |2
    | 3 |
    |4 |5
    | 6 |
    Take a look at e.g. the 4511, the 7447 or any other "BCD to 7-segment
    decoder/driver".
    It depends upon your display. You might want to count in octal, then a
    number of 3-bit counters is sufficient ;-)
    Note that the integrated decodes/drivers also have a feature to suppress
    leading 0s.
    Because the code it outputs is a 1-of-10 code.
    Josef
  9. Richard
    Richard Guest
    Hi. Yes, the 4 bit counters that I am reading about are all binary
    counters. Even the decade (BCD) counter is, except that BCD in the whole
    sequence of bits are not binary.
    And in this scheme I see how each display LED requires a Q1-Q4 output
    from a 4 bit counter.
    So to display a count of 7953 we need four, 4 bit counters:
    Q1-Q4 Q1-Q4 Q1-Q4 Q1-Q4
    BCD sequence:......... 0111 1001 0101 0011
    Decimal displayed:.......... 7 9 5 3
    Output of 4 bit counter is base-2 code.
    Not sure yet how you would get to display 7953 using the 10 bit counter.
    Whether in fact you would or could use 7 segment LED displays.
  10. Richard
    Richard Guest
    ........................ Q1-Q4 Q1-Q4 Q1-Q4 Q1-Q4
    BCD sequence:.......... 0111 1001 0101 0011
    Decimal displayed:..... 7 9 5 3
    (on 7 segment LED)
    Basically, how would you complete the above arrangement for this 10 bit
    counter:
    ........................ Q0 Q1 Q2 Q3 Q$ Q5 Q6 Q7 Q8 Q9
    ??? sequence:..........
    (on 7 segment LED)
  11. Richard
    Richard Guest
    BCD decoder (to drive LED driver)
    (on four 7 segment LEDs)
    Output of each 4 bit counter is base-2 code.
    Basically, how would you make out a similar arrangement to the above for
    the 10 bit counter? What would it take to display 7953 on four seven
    segment display LEDs? How many counters?
    ........................ Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 Q9
    ??? decoder:..........
  12. Richard
    Richard Guest
    Are we saying for 10 bit counter when the count reaches 7953 we have:
    1 in 10 sequence:...... X X X X
    X = HIGH
    1 in 10 decoder: (To drive LED driver)
  13. Am 30.6.2011 schrub Richard:
    Without some additional circuitry: you can't!
    The 1-of-10 code does not directly map to the 7 segments. You'd need a
    couple of OR gates:
    Segment 0 (the top most bar) is on if
    Q0 OR Q2 OR Q3 OR Q5 OR Q6 OR Q7 OR Q8 OR Q9
    is on
    The BCD to 7-segment decode/driver chips use a slightly more complex
    logic to determine which combination of the 4 bits causes which segment
    to light.
    It would be a nice exercise for Karnaugh-Veitch (sp?) diagrams!
    Josef
  14. Richard
    Richard Guest
    Do only 4 of those 10 outputs (Q0-Q9)contain the numerical information
    to display a numerical digit?
  15. Richard
    Richard Guest
    Well, I thought I'd better read the MC14017B notes. :c)
    It says: " The ten decoded outputs are normally low, and go high only at
    the appropriate decimal time period".
    I've little idea how this explains how the counter is used to display a
    count with (say) 7 segment LED displays.
    But, seems the key is in the quote.
    What has been decoded?
  16. Richard
    Richard Guest
    This is what I'm seeing:
    Lets say the clock frequency is 1 hertz. And the objective is to make a
    counter to count up to 9999 seconds.
    *Using four, 4 bit decade counters*
    We connect up four 4 bit decade counters. Lets represent the 16 outputs
    shared amongst the four counters as follows:
    IC1 IC2 IC3 IC4
    Q0Q1Q2Q3 Q0Q1Q2Q3 Q0Q1Q2Q3 Q0Q1Q2Q3
    Each IC output is weighted or coded, inasmuch as each output represents
    a particular numeral value. Individually for each IC, Q0 (LSB) is 1's,
    Q1 is 2's, Q3 4's and Q3 8's (MSB). As the count progresses the outputs
    become "hot" and spread along the 16 pin outputs. In this scheme, any
    combination of outputs that are hot is (almost) possible. Almost because
    the counters are decade counters and not binary counters.
    From a decoding point of view, each 7 segment display needs a BCD
    decoder, because the logic states on pins Q0 - Q3 is BCD. As the BCD
    value rises, this makes a display show 0, 1, 2, all the way to 9.
    At the start all displays read 0000. The display associated with IC1
    will cycle from 0 to 9, and on the tenth pulse, go back to 0, whilst the
    display controlled by IC2 will go to 1. At some point the counter will
    show 7953, meaning 7953 seconds have lapsed. Q1-Q3 on each IC does cycle
    in a loop regarding the binary number that is reflected in the output
    states (cold or hot). Each goes from 0000 to 1001 and back to 0000.
    *Using four, 19 bit Johnson decade counters*
    I'm not actually sure if I'm trying to mix oranges and apples, whether
    in fact this Johhson counter is suitable for use in counting clock
    pulses as I've described above.
    If we need four Johnson counters with 10 decoded outputs we have:
    IC1 IC2
    Q0Q1Q2Q3Q4Q5Q6Q7Q8Q9 Q0Q1Q2Q3Q4Q5Q6Q7Q8Q9
    IC3 IC4
    Each IC will only have one output that is hot at any given moment.
    Going by what is said, at the start, Q1 on IC is hot. I suppose Q1 on
    all IC's is hot.
    On the first pulse Q1 will be hot, Q0 cold. Again, not sure about what
    is happening to the other outputs on the other IC's. I think after the
    tenth pulse Q9 on IC1 is hot. Not sure what outputs are hot on the
    9753rd pulse, except that only one output is hot for each IC.
    But, whatever the state of the outputs, I'm trying to discover how the
    state of these outputs on the four ICs lead to four, 7 segment LEDs,
    showing elapsed time.
    I understand how counting, using 4 bit decade counters works. How each
    IC produces a BCD output, and that these 4 outputs on each IC is decoded
    in order to get each LED display to show a numeral.
    I don't understand at all, how the outputs in the Johnson counter chips,
    with their form of outputs, can eventually lead to each LED display to
    show a numeral.
    I could be trying to mix apples and oranges. I don't know.
  17. It isn't, you're using the wrong device.
    The 4017 would work if for each digit you had 10 LEDs, labelled 0-9. ONly
    one LED would go on, to indicate the count between 0 and 9. Once upon a
    time, the readouts were like that, Nixie tubes that 10 distinct numbers
    in an envelope, and a BCD decoder would turn the BCD into one of ten
    distinct outputs to turn on the needed digit.
    The 4017 is a bcd decade counter and a bcd to "1of10" decoder in the same
    pacakge. Since it doesn't output BCD, it won't work for thise project.
    7 segment readouts don't work that way. There are 7 segments, but for
    each number you have to turn on a number of those segments. Hence there
    are BCD to 7segment decoders, which take the BCD code and turns it into
    the outputs that will turn on the needed segments to display the matching
    number on the 7segment readout.
    These are not the same thing. If you want to drive a 7segment readout,
    you need a bcd output counter, then a bcd to 7segment decoder. The 4017
    is useful as a simple decade counter, and for things where you need an
    distinct indicator for each of the distinct digits 0-9. There are lots
    of uses for that.
    There are lots of bcd counters that will do what you need, and I assume
    one can still get BCD to 7segement decoders.
    Once upon a time, these things were common enough that one could find
    devices that had the counter, decoder and even a latch between the two in
    a single package, one company even put it in the same package as the
    readout. But they were expensive.
    Michael
  18. Richard
    Richard Guest
    So, the 4017 is a bcd decade counter. But it has a decoder that decodes
    the bcd, such that only one of the 10 outputs is hot at any given moment
    or time.
    As the count progresses, each clock step leads to the next output going
    hot. So, in 10 pulses, every output has been hot at some time, and the
    cycle repeats. In theory then, to make one Johnson decade counter IC
    control a single 7 segment LED, you would need a further decoder that
    assigns the appropriate series of LEDS that are to be turned on, for
    each of the 10 inputs possible. But, that is just not done. The 4017
    was not envisioned to run 7 segment LED displays. Will run a nixie tube
    though with suitable driver.
    That's what I understand at this point.
  19. Rich Webb
    Rich Webb Guest
    There is no "bcd" (binary coded decimal) involved in the 4017. It's a
    decade counter with a carry out. As clock pulses come in, the discrete
    outputs Q0 to Q9 are asserted, individually, in order. Wipe BCD from
    your mind.
  20. Richard
    Richard Guest
    What has slowed me down a bit is a sort of assumption I've had about
    counters. I've been thinking that a counter is a counter is a counter.
    When in fact you cannot just select any counter for your needs. When I
    say mixing oranges and apples, this is what I am referring to. You do
    that when you try to treat all counters the same. When seeking to use 7
    segment LED displays not all counters have outputs that are suitable.
    The 4017 is not suitable, because although it is a decade counter it's
    outputs are "1in10" type and there is no "1in10" to 7 segment LED
    decoder available. If there was it could be a substitute for a counter
    whose outputs are BCD. People mentioned that, but when starting out
    things sometimes just pass you by.
    I don't think there is any BCD in the 4017 because it's a ring counter.
    So, whatever decoder that is in that IC, (the outputs are "decoded
    outputs")it's not decoding BCD to 1in10. I don't think so. I don't know
    what is decoded.
    I've learned something. Thanks for all contributors. Rich
