countdown timer
Discussion in 'Electronics Homework Help' started by pavan, Oct 9, 2010.
  1. pavan
    pavan
    3
    Oct 9, 2010
    Hello everyone
    I am looking for building a count-down timer with no micro-controllers in it....
    and there should be a option to set the time manually and display the time correspondingly.
    can any anybody suggest the circuit diagram....
    can any one help...??
  2. Militoy
    Militoy
    180
    Aug 24, 2010
    By eliminating the option of using a microcontroller in your circuit - you may be adding significant complexity to your design. Is this a "challenge" homework project - or are you just leery of using a microcontroller?
  3. (*steve*)
    25,418
    2,788
    Do you want it to display an actual time (i.e. clock time 1:00:00 -> 0:59:59) or just a count that decreases (e.g. 9999 -> 9998...) [edit: or is it a clock?]
    Does the count represent seconds? or is it arbitrary, or is it some other period?
    How many digits?
    Count up, or count down?
    What should it do when it hits 0 or 9999 (or whatever is the max count).
    Is this a school project?
  4. pavan
    pavan
    3
    Oct 9, 2010
    Need to display actual time. There should be an option to set the time . (countdown)
    Display format should be in hours minutes seconds.
    Its a countdown timer.
    when the count reaches 0 there should a beep .
    ya its a project.
  5. (*steve*)
    25,418
    2,788
    Well, this sounds like far too complex a project for a beginner, so clearly you are expected to know something. What have you figured out yourself, and where are you having problems?
  6. pavan
    pavan
    3
    Oct 9, 2010
    The problem I am facing is that I not able to display the time in standard format.. i.e in
    hrs min sec(decrementing)...
Similar Threads
Loading...
