Hello all. I joined this forum because I have a small project that I need help with. I'm a fairly mechanical guy but electronics is NOT my strong suit. Anyway, here is my project.
I have 4 little toy mechanical monkeys that I'm using in a display. Each monkey dances and plays music when turned on. I have gotten inside of them and disconnected the speakers because I only want them to dance, not sing. That all went well.
Each monkey has its own battery box that holds 3 AA batteries with an on and off switch on the side of each battery box.
Now...for my display I want to be able to turn on all 4 monkeys at the same time from a seperate switch located away from the monkeys in the back of the display. I will also be setting this display up and taking it down quite frequently so I was kind of hoping to come up with some kind of "plug-n play" type wiring harness???
I hope I explained this clearly enough. I could sure use some help. Any ideas (in real plain terms) would be great.
