John Larkin
OK, now you have some switched power, what generates the RF?
Switched power *is* RF!
John
10.4 * 10**6 * 6 * 10**-6 = 62.4 watts average power.
Hawk 2nd generation tracking HPIR CW RADAR AN/MPQ 39 power seems
to have
not yet been revealed publicly. It has been publicly stated that
the AN/MPQ 39 power output level exceeded that of the earlier
AN/MPQ 33, which was 125
watts. This is a vast understatement!
In sci.physics John Larkin
A gigawatt at what pulse repetition rate; 1 pulse per hour?
It may be near a gigawatt ERP, but I doubt that's watts RF into
the antenna.
I'd also like to know what you'd use for waveguide at those power
levels. It's hard enough to keep moderate megawatts contained and
the waveguide in one piece.
Wimp! Be a man and use a M-72. Does wonders to touch up those
cheesy
flame paint jobs on their rust buckets, too.
Service to my country? Been there, Done that, and I've got my
DD214 to prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
I saw a device called "The Mosquito", that emits high frequency
audio noise that can be heard by most young people, and not so
much by more mature adults. These devices can be installed where
these punks hang out, and eventually they find it irritating
enough to move on to some other place. Probably such a device with
power great enough, and a focused speaker, could be directed at
the miscreant and make him very uncomfortable.
Another possibility is a similar focused sound transmitter that
would very loudly play Opera, or Polka. Even better, mix the two
together and really scramble the few remaining brain cells of the
offender. Have an automatic volume control to set the transmitted
sound level to be proportional to that detected. Probably 140 db
of Kathleen Battle and Happy Louie would do the job. And be at
least as legal as the offender's subwoofer.
But I'd also want to have backup from my buddies Smith and Wesson!
Paul
Big woofers, small testicles. You'd be arrested for malicious
destruction of property.
Uncle Al
http://www.mazepath.com/uncleal/
(Toxic URL! Unsafe for children and most mammals)
http://www.mazepath.com/uncleal/lajos.htm#a2
How exactly did that mode work, tracking target range but using EW
interference for az/el? How could you not know your az/el if you're
getting detections from your pulse?
The military reference says that they power and store the energy beam
equipment with resources that are used for VTOL hardware in other models.
Wires have less inductance if they are really short.
Don't know
Pulse radars use the same antenna to send and receive.
Put it under a streamlined radome.
In sci.physics John Larkin said:On Mon, 20 Aug 2007 22:25:02 GMT, [email protected] wrote:
John said:The array radars on the F-22 and JSF are reported to hit gigawatts
peak, and may one day get into the terawatt range.
Spob said:Would it be possible to build a gizmo that could be surreptitiously
aimed at the offending stereo system to fry some crucial components?
Sitting at a gas station as some backwards baseball cap and saggass
britches wearing kid parks in the fire zone in front of the store with
some fukdamuhfukinniggahbeyotch crap blasting out of his truck for
everyone's entertainment, got me to thinking.
It would have to be able to do it on a pretty localized basis without
causing damage to the person aiming the gizmo or innocent bystanders
or their car's electronics. Whether it would fry any additional
components of said target punk's car isn't of great concern.
Call it The Rapper Zapper.
Just wonderin'.
The TRR was slaved in azimuth and elevation to the TTR.
The TTR had the required hardware to track in azimuth and elevation.
When jammed, the TTR tracked the jamming source.
The TRR provided only range information.
The TTR was X band.
The TRR was Ku band and frequency agile to get around the jamming.
Fred Bloggs said:You got to be some kind of genius to do an average power calculation like
that, you know that? I could understand if you were really really old like
say 67 or more
Ummm, no.
Switched power is just switched power.
There has to be a microwave RF generator somewhere.
[/QUOTE]In sci.physics John Larkin said:Ummm, no.
Google "uwb transmitter".
Good grief.
A phased array requires precise phase (or frequency) control of the
emitters to do the beam forming and aiming.
How does one do that with a "uwb transmitter"?
[/QUOTE]In sci.physics John Larkin said:A phased array requires precise phase (or frequency) control of the
Timing.
Point totally missed.
Which phase (or frequency) of an Ultra Wide Band transmitter do you use?
You can't use all of them.
