E
Eric Anderson
I have an application where I have to move a 3 lb object in a 3 ft
cubic space. I am not looking at high performance or high accuracy.
It can take as much as 30 seconds to traverse the 3 ft distance and
the accuracy could be no better than 0.020 or 0.050 inch (possibly the
spec could be even looser).
Linear actuators would appear to be the best solution, but I am
finding that they are hundreds or even thousands of dollars. The
product I want to build will have to cost no more than $2,000 for a 3
axis device with controller, overhead and profit.
What is it in a linear actuator that costs so much that you could not
build a low cost version using a threaded rod, servo or stepper motor
and an extruded frame for a lot less?
Does anyone know of a linear actuator that can provide the kind of
performance I am looking for for a couple hundred dollars?
